Of all the experiences with clutches, which one is best placed is the original?
Black diamond knows if it works well ????
Is FCD2 a good option? or try to change the seat ibiza 130 hp map sensor and change the plug?
What do you think of the solution?
or try with FDC2 ??
As I said, the FCD2 does the job well enough, but it's not perfect. As to the Ibiza MAP sensor, I don't know. That would be something you would need to talk to your mapper about using.
I'd recommend Exedy OEM spec clutch. I don't have an experience with the Black Diamond one. But for an uprated disc I have the 2JR one, but yet to use it.
