Nissan Almera 1.4
why?!
not tryna be funny, just makes sense to save aligning twice, doing cv boots n joints was silly too considering.
unless you're backin outta the box....:P
Haha, yeah i was under the thought i was gonna change the brake lines, so thought meh who gives a shit, then realised these were rounded off, so stuck to these..
lucky no rips or nowt tho :D
---------- Post added at 22:09 ---------- Previous post was at 22:09 ----------
That box is not gonna be going on straight away..
why?!
Well got the alignment and all that mallarky done on it today..
Well..
This cars come off road.. again!
Not sure what im gonna do with it this time. Whether to build it up as a nice daily again or just a weekend toy car?
Anyways got started on a head i had lying around...
Exhaust Port
Inlet Port
Spray bars?
Shims missing?
..its whats under the opening for the oil filler hole, just used to aid spreading the oil quickly..
Can somebody confirm what head this is?
I've been told few different things, its a GTi head with NonRR bits && Its an early highport head && Its an early lowport head?
Can somebody 100% confirm what im dealing with lol
1N5 V1 - SR16VE
1N5 V2 - SR20VE
5J -
51N -
52F - Larger Exhaust Valves Silvia engine
53C - JDM Pulsar GTi-R. 8.3:1 T28 Turbo Low Imp. 444cc Injectors Larger Top Mount Intercooler Larger Oil Cooler Solid Lifters Ind. TB's Oil Squirters
53J 2L- Flat Pistons, highport, egrless and gold/black Valve cover (*)
53J 2R - Normal pistons, highport, egrless and gold/black Valve cover
53J 4R - found in South African Nissan Sentra's and Sabre's. Silver valve cover and 10:1 compression.
53J 7R. Gold Valve cover with black strip down middle, egr-less, tubulor exhaust, highport
53J V1 - USDM Black Channel Valve Cover Highport 9.5:1 1990-92 Red Injectors EGR OBD-1
53J V2 - 1R USDM Silver Valve Cover Highport 9.5:1 Red Injectors EGR OBD-1 1993 RIBS
53J V3 - 5R JDM Ribs on head Silver Valve Cover Red Injectors Mitsubu Alt. tubular ex. manifold 1/1 in circle and /5 in circle on head beside 53J
53J V4 - JDM Black Channel valve cover
53J V5 - JDM Silver Valve Cover No Ribs
53J V6 - BlueBird SR20DET 8.5:1 sodium filled valves 7mm stem Oil Squirters T25 Turbo High Imp. 370cc Injectors Top Mount Intercooler Oil Cooler Hydraulic Lifters Single TB
53J V7 - JDM Black Channel valve cover tubular ex. manifold 10:1
53J V8 - 2L W11 Avenir 8.5:1 silver valve cover Ribs 370cc purple injectors T25 ball bearing turbo Big TPS No EGR Mitsu altenator High port Internal coil OBD-I Stock oil catch can steel pipe has a built in restrictor.........the one the runs from the valve cover forward then behind the distributor to the stock catch can. same BOV/CBV as teh 1stGen DSM
53J V9 - W10 weaker BOV then the W11 Non ball bearing turbo 8.5:1
53J V10 - 3L 10:1 JDM bare aluminum cover w/ black in the middle No Ribs under the coil there is a circle with a line through it and a small number 7
53J V11 - 2R I think this is a W10 BlueBird SR20DET 8.5:1 sodium filled valves 7mm stem Oil Squirters T25 Turbo High Imp. 370cc Injectors Top Mount Intercooler Oil Cooler Hydraulic Lifters Single TB Red V/C black channel
53J V12 - 3L JDM Ribbed head, All silver valve cover, either a 6 or 9 and a 1 in circles under the coil.
53J V13 - 8R JDM with an 8 in a circle behind the coil bare aluminum vc tubular header external coil and egrless of course highport ribs on the side of head
53J V14 - 8L USDM Ribs 93 NX2000 All Silver Valve cover 9.5:1
54C - N14 Pulsar DET
54D -
58Y - SR18DE JDM highport.
64J - SR18DE SR18Di JDM lowport.
65J - 2R 2J2 10:1 JDM Silver valve cover
78E - BlueBird SR20DET (53J Head) Larger Exhaust Valves
79E - Larger Exhaust Valves
89H - SR20DE Silver Valve Cover U.K. '94 SLX P10 lowport No ribs 10.0:1.
89J - SR20DE Red Valve Cover UK lowport sodium filled valves 10:1 Gray 259cc Injectors .
94Y V1 - 3L SR20DE US lowport 9.5:1 OBD-1 1994
94Y V2 - SR20DE US lowport 9.5:1 OBD-2 1995-99
96J - 1R UK Redtop 10:1 Highport (UK 101 1R 96J head)Gray 259cc Injectors Mitsubu Alt. sodium filled valves
Unknown - USDM B15 Roller Motor Nonpainted VC 9.5:1 OBD-2
Unknown V1 - AUTECH 11.5:1 175hp for Lucino Nonpainted VC
Unknown V2 - AUTECH 11.5:1 180hp for Primera Nonpainted VC
Unknown - 53J 4R, JDM 53J 3L, 53J 1R McRib USDM, 53J 4J???, 53J 4L
Cars With 10:1's or higher
Nissan 100Nx GTi
Nissan Sunny GTi
Nissan Almera 2.0 GTi
Nissan Almera Tino 2.0
Primera HNP11
Primera 2.0e HP10
Primera 2.0eGT (5 door) FHP10
Primera 2.0GT FHP11
Primera 2.0Te HP11
Primera 2.0T4 HNP10
Primera Wagon WHNP11
Nissan Primera Wagon 2.0 WHP11
Prairie Liberty GF-PNM12
Autech Sunny Lucino Version B13
Autech Lucino Version 3 door N14
Autech Pulsar SERIE Version N14
Pulsar GTi Autech version N14
Autech Primera 2.0e HP10
Tommy Kaira ZZ-S
Tommy Kaira ZZ
Nissan Avenir GF-PW11
Nissan PRESEA 1.8L R11
Its this
whats it off tho?
/edit, i had that list saved on my desktop but it didn't come to me have a look! DOH!
Its a lowport non roller rocker head. Probably out of a P10.
You might want to use a sanding bit (instead of grinding stones) to get a better finish on those ports.
Had this up for sale, but a combination of not proper interest and me not to keen on selling it has led to some new plans for this..
Not revealing too much at the moment :)
Engine taken out this one for now..
