I got that data from the website, dont shooot the messanger i know its bollox as ive seen a review on UDox pullies on sentra forums with graphs etc..
it was,nt aimed at you you tart
frank
The OBX pulley is a piece of crap like all of their stuff. No seal protector sleeve and no timing marks. Bogus.
which set kris?
1kg from some 4 inch pulleys has fuckall momentum when compared to an 11 inch flywheel :roll:
(ie, lightening the f/w has FAR more affect !
frank
centrifugal forces are radius x omega x v squared or something crazy (way over my head )
and under-driving is only of use if you,re running at higher rpm than the factory assumed surely ? (ie, trackday,
and if you,re underdriven during normal use then the waterflow will be insufficient, the steering will be heavy and the battery goes flat)
frank
The power steering is interesting however as at idle it would be at its heavyest.. as a small increase in RPM would make up for the defecit in terms Steering wheel Effort.?..
is,nt the p/s pump governed tho kristian , ie, only actually pumps when pressure is needed (so the factory "gear it" so that full pressure is avaliable even at tickover)
frank
and the sole reason for lighter f/w,s ect is for exceleration surely (ie, you dont actually "gain" any power, its just akin to removing weight from the car
frank
This is true. but the Flywheel DOESNT DRIVE anything.. its simply a dead weight.. The crank Pully is affectivly pushing and pulling, in addition to being a dead weight.
