so today my new project began. i got the hold of stewarty04's old gti, previously sims.
things that i need to do before changing the engine over include getting hold of the below items and building it back up again
1. rocker cover
2. air box
3. fpr
4. radiator
5. cams
6. cam gears
7. refit starter motor
8. check ecu (dastek was cut out and some wires are left loose)
9. engine oil
10. coolant
11. battery
12. ssa manifold
13. check, check, check.... and check everything again
14. fire it up and hope that it works!
then and only then can i swap it over in to the gx
im looking forward to this!
1. rocker cover
2. air box
3. fpr
4. radiator
5. cams
6. cam gears
9. engine oil
10. coolant
11. battery
12. ssa manifold
