So Grinder was introduced to Wishbone mount tonight, Got on well i would say.
Although...
That took so much effort. First grinding the end of the nut off which still wouldnt come out, to then grinding the whole wishbone off, still nothing. So jamming the grinder in the mount soon solved it and out came wishbone.
New wishbone :
Put into place with biiiig bolt.
Bolted up to chassis
Then all tightened, Main bolt torqued up to about 130 lb/fts.
In place ready for hub to be fitted,
Then ARB removed,
Toothpick comes to mind, its that skinny.
If it is gonna be refitted in the future it will be sanded, painted and added with some fresh ARB droplinks and possibly some poly bushes.
Also on the coilover front. With thanks to Darchitecht, delivered today were 2 Daiyama 63mm springs. 5kg springs from N15 Coilovers, straight fit and alot softer than the original corsa ones.
One fitted :
Other side still to do.
Also the whole passeneger side has been sanded down ready for painting.
Also started on sanding down the bonnet.
Start ;
Halfway ;
Finished ;
And then started on the front bumper.
Start ;
Washed down of oil and dirt,
Fog blanks removed ;
And the deep gouges on the edge ;
Sanded down and filled ;
Left to dry until next time.
Then outcame the fire extinguishers again. So hometime.
Will finish sanding down bumper then tailgate area next time then probably started cutting out some more rust for a bit of welding!
Also if anyone has a set of bonnet pins for sale then speak up. In need of two sets.
