(click for bigness)
205/45/17, PCD-4x114, Offset-35, Bore-66.1,
They fit fine but passenger-side front sticks out a tiny bit too far for my liking - we'll see when I lower it if it's too much, maybe a 38 offset would have been better?
The edge of the tyre is about flush with the outside of the arch, that pic's not brilliant and makes it look worse than it is.
The wheels you link to on that site have the right PCD (probably, I've seen N16 listed as 114, 114.3 and 114.4, just check with seller first) but an offset of 45 so the inside edge may be too close your suspension unless you used spacers and then the outside edge may be outside the arch.
According to the site I use for suggesting wheel sizes 42mm offset is supposed to be the max for an N16.
