96 Silver Autech GTi
Some pictures from today. Ive been working on it for a few hours each day for about 10days now.
Major work thats taken place:
New dampers with OE GTi springs
New front caliper seals
New front pads
Front calipers repainted
New rear pads
Rear calipers repainted
New wishbones
New steering arms
New rose jointed track rod ends
New drop links
ARB removed and repainted
ARB bushes regreased
ARB drop link bushes regreased
Front & Rear arches ground back to bare metal, kurusted and primed
Skirt mounting holes ground back, kurusted, primed and will be filled when I get more sandpaper
Rear end kurusted, primed and undersealed
Inside rear arches kurusted and undersealed
Alloys resprayed
421 Manifold wrapped and fitted. Same size downpipe as standard, primaries are 5mm bigger in diameter though
Some pictures so far (some of whats listed above hasnt happened yet):
Which car looks like its being broken for spares? Its hard to tell.
I want my rear end hammerited
I would recommend every member removes the rear bumper to check whats going on, the black in the picture is basically where the rust was creeping up.
Cheers for the comments guys, I hope its worth it in the end, I am absolutely shattered, old spring clamps were a pain in the arse today.
fair ol crack there pal, will drive just so nice afterwards too. mini detail next?
el snapo el header head bolts eek
Yep a long over due proper clean up is definately needed!
Though it looks like they snapped, its actually not. 2 studs came out as I was unscrewing the nuts!
