Slightly off topic, but could anyone tell me what the standard C/R is for the SR20DE, SR20DET, SR20VE and SR20VET ?
Thanks.
What you would need would be the P11-144 gearbox.
You would then be able to swap gears from the N16 gear stacks into the P11-144 gearbox, albeit the 5th and final drive ratios (as the rest are the same).
Ok thank youUnfortunately these days you are more likely to get the info you want on the official Facebook group. This thread is now 6 years old and you probably won't get much response other than what you have already had on your other threads.
The primera gt is a 4.3 diff ?144 box RS5F70A only has 4.1fd or using the QG18 gearstacks that gives you a 3.8fd
RS5F32A FM43 is the primera GT gearbox.
P11 98/99 box has 4.1 diff & 1.836 2nd gear. But 00-02 the box changed to 4.3 diff & 1.955 2nd gear I thought?
Thanks for the info, the gearbox code ratio etc are a mine field.P11 GT only - RS5F32A / transaxle code 2J707 with final drive 4.375
2nd gear is 1.8261
P11 -144 RS5F70A / transaxle code 6J016 with 4.1765
2nd gear is 1,9545
I 've read QG gearstack is interchangeable with the SR20 P11 144 RS5F70A / transaxle code 6J016 gearbox haousiing.
You can play with that , to got better FD.
