K
KimJ
What kind of clutch do you have on? Guess the stock one aint strong enough.
rowdy-GTi said:The sr20 tranny bolts to the GA block ok then?
GA16DNE-T said:it´s not plug and play but y can be done, and the difereence of the 2 tranny its amazing
tla-gti said:Does the bell housing bolt holes fit the crank case or do you have to make an adaptor plate?
Great figures though mate well done :thumb:
InsaneUA said:Are there any experience concerning the stock GA16De's time of life with >200hp power?
Won't it die in 3 month? Does anybody know?
Damo-Sri said:Right fuck it, im going to turbo mine! You are my hero!
Dale said:^ a thicker head gasket, or some sort of plate to raise the head, usually mate..
i suppose you could get shorter pistons too but then the pistons wouldnt sit flush with the top of the block.
Basically your trying to make the combustion chamber bigger..
I doubt it, but it helps.. things like a good large intercooler and methanol/water injection will help to prevent detonation. im suprised the engine internals (especially the conrods) can cope with that kind of power (300bhp) though..this car has been running for about a year on standard internals, so it must be quite strong and well setup.cov_racer said:1.6 stand comp ratio is like 9.8:1 (i think) would a slightly thicker head gasket alone make enough difference to run this level of boost?
