Compression:
the is running std compression 9.8.1, I tried to put a thicker gasket but the knocking was a bitch, so i put the original gasket with 75LBS of torque, stock bolts handle this very well.
Gasket:
thicker gastek at low boost pressure wil detonate, so was running the car at 1,5 bar and no problem, but when it was running low boost knocking will come jejej
Pistons:
i cant put piston with lower compression cause nobody make this for ga16
Inyection:
water/meth prevents detonation
Timing:
also timing is set very conservative for prevent detonation.
Gasket:
Pistons:
Inyection:
Timing:
