Almeragt´s SR20VE Almera
well i work for renault/ nissan they are good cars have a few problems but nothing major
also we do, do discount parts delivered to your door lol! can contact me ith any questions about it and ill do my best to help you out mate!! if you pm me ill send you my email :) ill help anyone i if i can!!
... after 1,5 year finally arrived MFactory helical LSD
it was probably fit too. sam this bolts to the other half of the diff with the big bearing. pic of my initial one needing machining to fit
little update - another item to my box - I´ve managed to get also MFactory 5.167 final drive for SR16VE box I wanted since it was available... Thanks to Jagy, who found the guy, who will buy my MFactory 4.785 FD... Without his help I wouldn´t be able to buy the new FD...
Box is currently out of the car and will be hopefuly back in the car until Friday ... There will be done:
  • new bearings original Nissan for SR16VE tranny
  • MFactory mechanical LSD
  • MFactory 5.167 FD
  • new seals for SR16VE tranny - original Nissan
  • new tranny oil, Millers Oil CRX LS NT 75W140
  • new engine oil, Millers Oil CFS 10W50, NT
  • and will have to order new set of tires - my choice will be Toyo R888 this time...
sss4me: do you know, if is needed to "take out" the inner part of the OEM LSD, marked on this image with finger?
I´m really not sure... Don´t know, if I have really got the right part! /I mean LSD for SR16VE/
so thanks to sss4me and Stephen from MFactory, all is clear now , transmition housing has been sand down, and We took up rightly the backlash clearance of the diff... Advice for that, who will buy MFactory LSD - sanding down some areas of the housing + check the backlash is needed! Message from Stephen
Quote
with regards to clearancing of the transmission housing, if the LSD is hitting the transmission housing very slightly in some areas, you can use some sandpaper and sand down the transmission housing where the interference is, probably around 0.5mm. This won't affect the structural integrity of your transmission housing, and is easy to modify as it is just soft aluminium.
the reason for the interference is because the oem transmission housings are cast, and the area where the intereference is is not machined, so they are not a perfect circumference around the LSD i.e some areas have "bumps"
Unquote
photos of my seat frames - EVO 8 seat frames, custom made. Sorry, didn´t have time to make better photos... And car wasn´t cleaned...:
So the seat is thanks to my friend Roman finally on it´s place... He made also custom seat brackets, so I can move with seat like with OEM one and get the previous Recaro seat whenever I want or need - perfect job as always... Some pictures of the seat and brackets below:
Looks good, quite high up though...
My Recaro seats are much lower than OEM Almera seat and this one is 2cm higher than Recaros - still lower than OEM ones... It didn´t go lower, otherwise We would need to adjust the ground again, and I didn´t want to... Anyway, seating position is great for me, and feeling also...
