Whens it in for a tune/ RR session Andy?
You just running it on the stock ECU map at the minute or with the old dastek tune?
sam said:have you removed that bracket? not much need for it nemore..... ?
kristian said:bushes are from ?
kristian said:Also the injectors flowed 270 CC at 3 bar.???????????
... Who was i that was so sure that Nissan N15 GTI injectors run at 2.5bar.. at 270cc??
rowdy gti said:Yeah, but they rate/test them at 2.5 bar. ie GTi injectors are 259cc at 2.5bar, 330cc at 3bar. I know this because mine were flow tested
Yeah i noticed that and thought it was strange. Here`s my post......http://www.almeraownersclub.net/showthread.php?t=26332&highlight=injectors+cleaned
I questioned the flow rate and was told Nissan rate them at 2.5bar.
Im looking to get mine cleaned with the same guy, and this has now made me a little sceptical.
There cant be that much difference between two sets of stock GTi injectors at the same pressure, surely?
How is it mate, did you get it running in the end?
Try the connectors on the back of the starter, mine came loose. UNPLUG THE BATTERY first though
yaaaay, what have you done to that downpipe it looks huuuuuuuuuuuge?
