Andrew's new piccies
so youve not had it chopped off and new bit welded on? Ive got a 2.5" one on mine but that looks massive......
sr16ve rocker, bit scabby, so have ordered a new one from g-spec
Big spender hahah, that would have done for any of us fuckers :)
Joe
piccie update for the vvl head conversion
got all the parts now and starting to put it together
vvl oil pump
powder coated inlet mani
brackets all powder coated gloss black
built up and sr20de injectors installed
head all cleaned and checked over by the engine shop
new rocker cover
still need to remove the sr20 from the mera, ( hopefuly this weekend )then i can get cracking
You deserve a success more than anyone on this forum.
I dont know what happened with your previous engines and all the running problems you've had, but the effort, detail and quality of finish you put into your builds is second to none. I really hope this works out for you.
Hope to see this beauty back on the roads some day soon.
Good luck!
Good luck mate, hope it all comes together nicely for you :-) Totally agree with everything Dale said there, as you clearly put in such a great effort.
this is going to be an epic car one completed... im sure it will all come together fine... you have put soooo much time and effort in to this build...
i just cant wait to finally see it...
more powder coated bits
all gloss black apart from the tow hook in red
painted all these black last time and just turned crappy so doing it right this time
