I have been converted
if your looking to change your dizzy and rotor arm soon use nissan parts, me and rob have used pattern ones and it caused both to miss under acceleration, a genuine nissan one for a high port should be fine although I would like to try an almera one to see if it works...
does your temp needle stay halfway all the time?
Yeah its halfway all the time, apart from when it overheated on the M6 after sustained 80-90mph for about 3hrs.
Cheers for the tip on the dizzy, ive just been cleaning mine every so often.
Id personally recommend Magnecor KV85 leads instead of Splitfire. Ones for the UK N15 GTi will be fine.
Mine also used to miss under acceleration and it was down to a combo of things, i think some of the trouble with these cars is the low mileage (lack of use) and age of them.
