So i've been pretty busy lately....
An offer came up that i couldnt refuse, i aquired an SR16VE. Thought it was about time i got in on some VVL action.
So yeah, rather than swapping engines, this is a VE head swap onto my DE block with 16VE pistons.
I drilled and tapped the external oil feed to the gallery in the VE head.
Stripping the the DE down.
Head, be gone.
Removed oil pans and girdle ready to come out.
Pistons, be gone.
Cylinder bores freshly honed
SR16VE pistons and new rings fitted
Oil Pans refitted
Sealant of choice
VTEC head on
VTEC head assembled
So thats its basically, the motor was built a couple of weeks ago.
I finally got around to modifying the Mazworx header too.
Original specs:
1.75" diameter primaries
36" primary length
2.5" Choke
3" Outlet
New modified specs:
25" Primary Length
2.1" choke
2.1-3" transition
As it stands now, I've wired up a granatelli window switch and fitted the custom 4-1 Mazworx Header.
After waiting two weeks, Aldon let me down with getting the dastek rev limit module fitted to my ECU, so that meant i was going to be stuck with a 7400 rev limit.
So now instead i'm looking to use the 16VE ECU ( for its higher RPM limit) along with my dastek.
I realise the dastek and 16VE ECU is probably being asked a lot of now for this high comp VE/DE hybrid, but i want get the motor running as cost effectively as possible and didnt want to go down the line of Nistune because i'm still sitting on these roller barrel ITB's..so standalone may be in my future, but is currently out of the question funding wise.
Mapping has been scheduled for Monday 9th July, fingers crossed everything goes to plan.
Oh and i got my WORK rims professionally refurbed, im pleased with how these turned out, now they look like new!
