A 90 deg bend right at the throttlebody would be a turbulent restriction though wouldnt it? A regular side feed plenum would be ok though.
The idea of a centre feed intake in my head is similar to ITB's, delivering EVEN flow to each cylinder.
On our side feed plenums, No4 cylinder will typically recieve less flow. You could compensate for this if you are tuning cylinders individually, but normally otherwise we are compromising the engine tune, having no4 running richer than the other cylinders
Somebody has already tried a very similar setup to mine on a 2ltr VE, but he had a 90 deg elbow straight after the throttle body. He made 165ftlb and gained 15ftlb of torque over an xcessive N1 plenum setup. It did however loose HP after 7600rpm, probably because of that 90deg elbow!
I still have these roller ITB's yeah.
