Just a progress update.
So ive got everything i need to re-assemble my engine, except for 8 exhaust valves and a throttle body gasket. Both are on back-order at Nissan. I've managed to secure a deal on a set of geniune used valves through the company 'GTi-R-us', which are being posted out this week.
In case you are wondering here are the few parts which ive chosen to upgrade to compliment the worked head:
Valve Springs - BC Valve Springs
Hydraulic Lifters - Roller Rocker HLA's
Head Gasket - Cosworth MLS
Camshafts - JWT C3
Cam Gears - GSPEC Adjustable Slider
Plus a bunch of NISSAN gaskets, seals etc required for re-assembly:
Valve Stem Seals 6mm Intake/7mm Exhaust 13207D0100 and 1320784A00 (full set)
Intake Manifold Gasket 1403553J00
Plenum Gasket 1403253J00
Throttle body Gasket 1617579S70
Exhaust Manifold Gasket 1403653J00
Chain Tensioner Gasket 1307953J01
IACV Gasket 2378553J00
Head Bolts 1105653J00 (x10)
So i started out by lapping in the intake valves and then numbering them so they went back in the right place.
Then after a bit of a battle and white grease (not spunk), valve stem oil seals were changed. Notice the bronze valve guides.
Followed by installation of the Intake Valves, BC valve springs and steel OEM retainers.
Finally, the head has also been resurfaced.
I'll update more soon...
