Well got ma brakes sorted last week so its passed its mot, just need to fix the dent, the wing then a can start modding . Also fitted Phase 2 rear wiper arm today, looks much better
Rite, another wee update plus some help required,
First of all my car went into the bodyshop today so should have it back by the end of the week .
Now i need some help, i tried to spray the inside of my headlights, i only trie the indicator bit first, so put it in the oven at approx. 75 degrees C and kept checking it for about an hour but couldnt get it apart any help would be great.
Thanks Chris
Yeah I gave up on my indicators on the ph1, i ended up with broken bits of plastic flying everywhere. Like Ed says, its possible, but why not just paint the headlights inside and give the indicators a light smoke tint on the outside?
Edit - Or heat up a stanley blade and cut them apart, paint them, then poly cement/plastic weld them back together?
Erm, have a look, but i would say 20mm on the rear would get it looking pimp, with maybe just a 5mm slip-on spacer on the fronts? That what i'll be going for if i keep the ultralites, but it really does depend on the wheels!
