Main issue is though, that its been pinking it's tits off since i first started it, and to stop it pinking Jez had to back the ignition timing off to like 4' :wacko: lol Jez was also gobsmacked at the 250psi cylinder comp test readings.
This is why I was concerned about Jez mapping N/A motors...
I'm no engine tuner lol... but from what I can understand, on high comp motors you typically run normal base ignition timing (15* +/- 2*) then control the Detonation with the timing map... obviously keeping it conservative where needs be ??
Thats how I've always visualised it anyway.
I would say having your base Ingition timing set to 4* is fucking up the whole thing... like at the recent RR day... Rich's car gained 12hp from a minor tweak, and nearly 30hp from a proper 17.5* timing advance...
So who knows? Maybe the Turbo cars Jez is used to mapping just require shit loads of fuel and not much timing map adjustments?
Cos after all... The timing map is where the power comes from when N/A mapping
Hard Luck Craigybaby.. I just hope it gets sorted so you're happy man.
I don't think the comp's too high either BTW... I do however think the short duration of the N1 cams is too short for the C/R though, but thats another matter.
Joe
I would of kept the base timing to 15*, then just pull timing back box by box until pinking is gone. 12.5:1 should be fine on 99ron in a VE. They have a much better combustion chanber than a DE. You sure it wasn't piston to valve contact?
http://www.team-integra.net/forum/display_topic_threads.asp?ForumID=10&TopicID=27552&PageMsg=Viewing+Common+Topic
Just had a read of this honda thread ^^, which talks about moving the powerband up the rev range with cam gears, if i want to do the opposite then as my powerband seems most potent between 7k and the 8k limit i need to do the reverse.
It mentions tightenting the cam lobe seperation angle which in turn increases overlap, so i therefore need to widen the lobe seperation angle therefore decreasing overlap. I'm presuming to do this i need to retard my intake cam and advance my exhaust cam?
that sound about right?
obvioulsy this is best done on a dyno for the optimal results but the principle is correct yes?
other sideeffects according to the honda thread of widening the lobe seperation angle will be..
- decreased cylinder pressure
- decreased chance of engine knock
- decreased cranking compression and therefore 'effective' compression
PERFECT!!! given my knocking/timing issues already
any thoughts or corrections to the above welcome lol
Joe is right, retarding the base timing is just retarding the whole map. It's like fitting a AFPR and upping the pressure it's dumps more fuel everywhere on the map. Your losing 11* in every area of your map, I'm not surprised it doesn't open up until 7k.
I know he never checked valve/piston clearance on the high lobes, the test was engaging VVL :lol:
The comp's not too high slag
Dale, or anyone, shall i bother trying this lobe seperation angle thing like tomorrow? and what do you think will make much difference? i was gonna retard the intake 5' and advance the exhaust 5' too, but is that a bit much? just do 3 each and see?
