I'm not sure the car would even tick over if it was very wrong with s3r's so i think you've done it right Curtis, just need a bit of a tweak like you say. I was loosing power with my s3r's in and advanced on the inlet by 2.5 degrees before my remap.
to set TDC put a long rod or screwdriver down the spark plug hole and remove the distrbutor cap. turn the engine until the rotor arm is at/near number 1 and the rod/screwdriver is at its highest point. also the cam lobes nearest the chain do point outwards as i found this out when i built my engine
I had the bung fallout my gti intake before, car wouldnt even idle without throttle, took me a while to find the cause, had a hunting idle when I never tightened up the intake pipe to the TB too
I know alot of the people on pga had to run modified shafts (shorter) if they were wanting to run their cars low as they were suffering from driveshaft issues....
When i replaced the boot we did have trouble replacing and sealing the boot as its not complete round type, so the greese was able to leak, possible cause, but yes being low does effect it
