daily drive cams
you wont reach 200...... Il tell you now unless your willing to spend alot of money anyway
I bet if you dyno it then fit the cams and dyno it again you wont gain 20bhp, its not a simple as saying I have this many mods so I must have this much power
No disrespect but thats a clear 10hp more than anyone on here with stock DE cams. Does ths seem odd to you?
details of the chip if you dont mind?
even a jwt ecu doesn't give +14hp wow - my head hurts - fair play tho.
do you have a before and after dyno sheet to post too?
edit no stock timing 15* and 3.2bar of fuel pressure. with the poncams it went from 161hp to 177hp (untuned figures)
dd
He did 3 runs before chiptuning, best run 161.1 hp. After chiptuning he did 3 runs again, best run 175,2. I thought i would lost € 399 for 10 hp but lucky me got 14 hp. Can you send me a proper link to your tomei cams mate so i need to know where i can get them from?
I 'll get someone to scan it so i can post it
You need to understand that Dyno figures are BOLLOCKS, my car with cams alone, pulled 161bhp, then I fitted every other bolt on mod possible, header, decat, free flowing exhaust, good intake, lightened fly, fuel pressure regulator, lightweight pulleys etc, then it pulled 142bhp...
Dyno figures are nothing to rely on, its the quarter mile times that tell you how fast the car actually is.
You will not get to 200bhp without opening up the bottom end.
And no 20VE pistons are no good for our DE motors, you'll need N1 pistons for 11:1 compression or 16VE pistons for 11.7:1 compression.
Joe
I surely believe you without doubt. I just posted it because he asked for it. Tomei cams will be the last mod for me. Will proberly pull 190 hp on the dyno. The dyno station can also test a 0 - 100 for a + € 100
Cheapest price you'll find for JWT S3R's is from MyNismo.com, worked out nae far from $50 cheaper including postage for me (Y).
S3R's proven to be very good Joes recently got some.. but more importantly there like the one of the best u can get before u need headwork inc uprated springs etc
Just checked out there sitee.. they doo GA16 cams :drool:
