daily drive cams
You need to understand that Dyno figures are BOLLOCKS, my car with cams alone, pulled 161bhp, then I fitted every other bolt on mod possible, header, decat, free flowing exhaust, good intake, lightened fly, fuel pressure regulator, lightweight pulleys etc, then it pulled 142bhp...
Joe
I still disagree, I have your car dyno’d before and after on the same dyno on the same day is the best indication of gain or lost. Not going here there and everywhere and expect to see some kind of consistency.
Your 142bhp is rubbish, but that my opinion
david
to get consistent results on a dyno, you need to use the same dyno, the same wheels the same tyres at the same pressures the same suspension height/geometry so many factors come into play its not as simple as people think...
every dyno will differ pick one and stick to it
Does the rr engine also have pistons what would be a direct fit without honing. Do you need to hone the cylinder fitting sr16ve pistons.
I think you mean Boring?
as in increasing the size of the cylinder?
Honing is just the smoothing of the bore for the new piston rings.. this is required EVERY time you fit new piston rings...
The SR16VE pistons are the same 86mm bore as the standard SR20DE pistons, they just hve more material up top to bump the compression up to 11.7:1.
No Boring will be needed.. just a fresh Hone.
Joe
Ah ok. Yes i ment no need to machinal boring with sr16ve pistons. Will a local nissan garage do the job or do i need a specialist for this kind of work?
How about sr16ve pistons with nissan oem piston rings, i thought i readed it somewhere on the forums. What would be the worst thing what can happen. I don 't even know if it works.
Mera red gti ever heard of a company tokyo seven? tomei pon cam 140039 246,24 pound + shipping 32,04 (waittime 2 month) 278,28
http://www.tokyoseven.com/T7/product_info.php?cPath=29_65&products_id=283
:eek:
Thats quite good price
This looks interesting
http://www.tokyoseven.com/T7/product_info.php?cPath=29_65&products_id=403
0.6Litres increased capacity yet same ground clearence values... maby Joe interested in one?
