Joysams Almera N15 GTi 24h Endurance Edition
^^ ^ Posted on Wednesday....
Without coilovers you'll need camber bolts. Or you can elongate the top hole on the stut's lower mount. The rear is not adjustable at all without getting it bent.
Also you can get at least negative 2 degrees camber with this.
Thanks for great ideas!
The car will be used as a daily driver over summer and then be modified to a endurance racer.
Is200's are fairly over rated cars, here in Ireland every young wanna be drifter has one. Turn the car about 180° and they think they're gods. Raced one or two in my VZR as well as some altezzas had no trouble keeping up
Sent from my SM-G900F using Tapatalk
I did som measurements on the battery/alternator yeasterday.
The alternator is giving 16,6-17 V.
A little bit to much I suppose.
What is the first thing to check/replace?
Is the (don´t really know this word in english) alternators regulator (load rtegulator, load relay?) easy to change or is it just as good to exchange the alternator?
Yeah sounds like the voltage regulator is faulty. Is held on with a 10mm nut. Not sure if they can be purchased seperately.
Best bet is a second hand Nissan alternator.
