VE = Just over 200bhp for £1500 minimum
+T = Anything between 240 - 280bhp for £1500 or less.
did you miss the part where he has everything for the turbo conversion...
Turbo > NA IMO
a 200hp VE Vs a 200hp Turbo... the turbo will win all day. torque wins races.
I never mentioned aoc did I, why do you keep mentioning it.
You want a power hike get nitrous.
When you say a slight power hike you can still do that n/a.
Have you weight up the costs then?
Vvl head, n1 cams, remap= 200+
Cost= £1500.
Turbo conversion
Management
Remap
Fuel pump
New clutch
Possibility
Brakes
Cost?
Sim's your turbo conversion lost to Dales n/a right? Time wise.
Also a 200bhp turbo would not be a better drive than a 200 n/a.
I can talk, I've had both
Dale has 218bhp compared to stu 320bhp.
13.84 to 13.02.
So a 230bhp turbo?
Anyway not trying to cause arguments, just stating facts.
Turbo future potential yes 100% better, but based on a low boosted 230bhp set is it better/ worth it?
a well balanced build that has minimal lag but doesn't run out of steam high up will have an epic wide powerband and bags of torque, you wouldn't even have to try in it.
40mph rolling start N/A vs Turbo, because it would be a fucking embarrassment you silly prick.
Sig'd.
lol why whats wrong with that? or cos its comin from an n/a nerd?
Think about it.... Do i have to text you?
Hahah Craig you thick fucker.
Mov - You have the parts, so it makes sense for you to go Turbo.
As others have said a well built turbo'd motor has more power and torque than a built N/A like, everywhere.
The only downsides being Transmission/Shaft problems and Grip!
Put it this way - If I'd spent what I've spent on my N/A Build on a turbo motor it would have like 1000+ HP or whatever, but no way of transferring that power to the ground lol, so it would be pointless.
Joe
Yes to water feed. Without it you can coke the oil passages and eventually starve the turbo of oil. It isnt expensive, so do it right!
Gtir clutch and fly wont fit. The fly has different bolt size and the clutch is splined differently.
Leave the engine unopened for 250hp. Itll be fine. The hg is the same as a det anyway so its good to 250 easily.
