Damn I just found out that the ph1 ecu won't work with the ph2 loom. The NATS receiver around the ignition barrel is different..more specificly the connector is different, I guess I can't just use the ph2 NATS receiver with a ph1 ecu or can I? Think someone mentioned they are paired with the ecu.
