I deleted the pics by mistake on photobucket lol
It does look cold! Looking forward to when the grille is finished and you can get some nice pics
Still rocking the wheel trims? Should ditch them and run gloss black steelies
WCMUT:
you had the throats opened up mark ? and skimmed by how much ?
frank
Just skimmed by 1mm frank. Will calculate the chambers cc's soon, so I can have an idea how the compression will change.
I'm affraid I can't use the micra valves since the shop said they aren't made to take exhaust temperatures.
is it def 45cc stock?
volume of the combustion chamber in the head is actually 34cc. obviously thats not taking into account the headgasket thickness or the dish of the piston but atleast you know the size of standard and you can now compare this 34cc to your now skimmed head mark.
whats the 9.5?
you need to know the total area tho eh paul
and is,nt your stock C/R 9.5:1 ?
so its the sweeped area = 400cc (1 cyl) + the unsweeped area 47cc
thats 447cc, compressed 9.5 times (ie, made 9.5 times smaller) = 47cc.
and if the 1mm skim has reduced the unsweeped area to 43.5cc = 10:1 C/R
frank
got the spark plug in tight? only dropped 5cc?
I just measured the combustion chamber with liquid and it's 29-30ml or 19-30cc!
pi x r squared aint it mark ?
3.142 x 3.142 x 3.75 x 1 = 36.5cc = 10mm skim or 3.65cc for a 1mm skim ?
frank
