My Mera
Weird one that. No movement, not that hot. How do you think it got like that? Or was the pipe too short and under tension to begin with?
I think it was under tension as the cassette of the turbo is smaller so the drain is higher up. Should have noticed it really but got away with no damage luckily
Jubilee clip, they cut into the hose, same happened to my top rad hose, any tension they slice right through.
Are you sure that's proper oil hose you're using? Looks like rubber degradation to me. Glad you're all sorted though.
Im not sure i think it came from Liam not even sure on the bit h put on but going to order some as I need two bits with 90 degree bends in them
Not really done much with it recently but been meaning to fit a slim line fan as the bottom rad pipe touches the standard fan. Didn't want to use the cable tie through the radiator fixings that came with the new fan so cut up a old fan housing I had spare
Yeah not too many reviews on them but most are good. Only thing is the local tire place said they never sold them in the UK so got them from Germany haha
