Ok I was. As you can see I was struggling to see it
It still needs a few tweaks here and there before I'm confident enough
*CONTINUED*After a few shitty runs and a few boost hose issues, I came away with this time:
I'd say it's more the look of internal turmoil. Certainly has the appearance of a man struggling with his desire to reach out and touch someone.Despite how it looks I'm not actually looking at your cock.
What boost were you running on this that achieved the 1/4 time?
Fare play for keeping the head up with this build after getting so many knockbacks.
Am I reading this right? Are those figures measured in feet? and 1320 is a 1/4 mile measured in feet?
Also, is "reaction time" how long it takes to cross the line, after the lights change? I've never taken the time to investigate a race slip before.
Nice..thats quite a good time considering its at stock psi..Thanks, yeah I had a few moments with it but always moved onwards and upwards, all of the last few posts happened within about 6 weeks too so it was quick!!
It's just at Actuator Pressure at the minute (the minimum it can be) which is 0.8bar.
There is scope for more yes before you ask, the Turbo is good for 1.7bar and I have a map sensor setup to get round the MAF maxing out which it is on the verge of already...
I will probably only go to 1.0 - 1.2bar as a maximum though, that should be MORE than enough in this shell, it already feels quite ridiculous.
Yep the time slip measurements are in feet buddy... 1320 being 1/4 of a mile.
Reaction is the time between the green light, and when you pull away (which is only added to your actual time in competitions not practice days!)
Joe
Have you seen how extensively he has his cars weight reduced by?Nice..thats quite a good time considering its at stock psi..
Be interested to get my own de+t timed, running stock boost aswel..
Id imagine the quaife diff makes a night/day difference? ?
Ahhh,,, was thinking it was too good to be true running low 13seconds with that spec..Have you seen how extensively he has his cars weight reduced by?
Joe
Second run 1st gear was a lot better because you feathered it or it bogged,but you floored it in second,it spun up straight away n hit the limiter.
If you show a bit more restraint in 2nd you will get it lower
Great effort,well done dude
Still cant believe you get into 5th over the line...
