Will look into the issue, sorry.
We did test the fix on SteveC's care.
We have already revised the kit, and it was no problem to use a off-set bushing,
but our engineering team advised if we used a off-set bushing, we had concerns that some customer will install to the wrong side.
Therefore a different solution was researched. So we lengthen the eyelet (the aluminium parts) and that will also remove the chance of having a rubbing issue and we taken the measurements.
We saw that in the pictures the car is jacked up to take the pictures, that's why there is a rubbing problems.
But if you put the car on the ground, there will be no problem.
Whoa there. Nipping this in the bud right now.
The inner top mount stud? Yes it can be a problem, a lot of people just hacksaw the bit off the inner hole on the strut brace itself, or some have just fixed it on the 2 outer studs.
i didnt measure mine really, i set mine up and measured the gap between the threads between the spring lock nut andthe bottom mount lock nut, cant remember what it is really, i just fiddled about with them (4 times) until it looked right.
are yours knocking at the back? plus are they rubbing like mine were?
i havent sorted the strut brace problem yet either lol, think im going to hacksaw the bottom of the brace off, didnt fancy having them held on with 2 studs
As this was a specific fix that most were aware of on here maybe reverting back to the off-set bushing will be safe Kev? As we know this works on the N16s too? and yes great sign that you're still in touch (better than the daiyama coilover fiasco!)
might stiffen up the damping a bit then and a tad on the springs as well. God damit lol mean stripping out the rear bloody seats again, get pee off with have to take out 100's of 10mm bolts
