Loads better with front engine mount bolt disconnected. Want to put standard back on though. Vibrations at idle still being transmitter through bracket though. Will remove poly completely like Liam did.
Clutch judder is minimal at low rpm (below 1100rpm), but above that it's smooth and positive but not too abrupt. Feels good.
HLSD is awesome as expected. Loads of pull and grip in and out of corners no matter how tight and even needs a lot of throttle to spin wheels in the wet.
All the other chassis mods, the car feels so sure footed now. It was good before but this is a whole new experience now.
Turbo is good but need FCD set up for 2bar to make the most of it as only running max MAP pressure right now (1.5bar).
Brakes are positive and progressive.
Mapping tweak and FCD setup next.
-phone-
-phone-
