ok i did some more on the swap wiring tonight, as it was raining i fired up my old power supply and had at the PH2 lights to work out their connections, these are very easy also but i'll put the info up anyway. the main 5 pin connector is the most important and nissan have kindly numbered the wires in the connector to make things easy for us so you don't really need to worry about the wire colours (though i will add them just for posterity) just go with the numbers
one thing to note is that on the nearside headlamp the number one pin is at the top side of the light and on the offside it's at the bottom. next up is the indicators, again they arevery straight forward
finally there is the beam adjust wiring 3 pin plug, on both of these plugs the centre wire is the command wire which gives the position and the other two are positive and negative,
now i'll add more updates on the car wiring for the indicators and beam adjusters as and when time/weather permits and when it's all done i'll either finish the existing howto thread off or thow up a new one so all the info is in one place :shades:
Code:
Offside Main Connector | Nearside Main Connector
Pin 1 = Shared negative - Black&Silver | Pin 1 = Shared Negative - Black&Silver
Pin 2 = Full Beam Positive - Yellow&silver | Pin 2 = Full Beam Positive - Red&Black
Pin 3 = Empty | Pin 3 = Empty
Pin 4 = Main Beam Positive - Purple&silver | Pin 4 = Main Beam Positive - Red&Yellow+Silver
Pin 5 = Sidelight Positive - Red&Green | Pin 5 = Sidelight Positive - Red&Green
Code:
offside indicator | nearside indicator
pos neg | pos neg
yellow&green black&silver | green&black&silver red&black&silver
Code:
offside beam adjust | nearside beam adjust
pos command neg | pos command neg
red&green purple black | red&green purple black&red
