well tbh I decided against using the gti shifters due to your sr20 swap thread saying they needed cut and extended so although I had access to a set off nistros old gti I never bothered pulling them, and when it came time to hook the linkage up and i found that the qg selectors wouldnt work there were no gti's near me in scrappys etc. so after looking at the fsm's of a few cars I worked out that the ph1 n16 di selectors would work with the gti rear mount and gear select connection, and as I knew where one had recently been scrapped that's what I used. I still don't know to this day if the gti set would work without modification but I can get you the measurements of the di one to compare against if you'd like?
