SO my current mod list is:
Engine & Management
SR20ve
SR16ve Cams with Stock 20ve cam gears
Calum Basic chipped ecu with custom tune
Vtec controller for VVL activation
Intake & Exhaust
HKS Filter with velocity stack
Custom intake pipe
SSAC Header modified - Longer and bigger dia secondaries and 2-1 merged collector
Custom 3" exhaust - mandrel bends
Magnaflow 8"x5"x24" Muffler
Magnaflow 6"x18" round resonator
Drivetrain
SR20 gears with SR16ve Final Drive (4.44) and SR16ve LSD differential
ACT heavy duty pressure plate
ACT Street disc
Fidanza 8.5 Flywheel
Suspension & Brake
VZ-R Front brake - Hub, caliper, rotor, pads
VZ-R Rear brake - Hub, caliper, rotor, pads
Front - Stock Springs (cut 1 coil for height) and serviced shocks (140 grade gear oil in damper)*
Rear - Tein HA coilovers
VZ-R Stabilizer bar
Aftermarket Strut Tower brace+
Interior & Exterior
VZ-R Front and rear seats
VZ-R gauge cluster
VZ-R Shifter & center console
Apexi Rev Speed Meter
VZ-R Headlamps
H.I.D. kit - 8000K
Disposable Fire Extinguisher
VZ-R 15" Wheels (sprayed dark grey) wrapped in 205/50/15 Maxxis MA-V1
* Front ones will be sent to TeinUSA for repairs
+ Rear brace from VZ-R to be installed.
Peace
