SOOOO
since fitting the oil cooler and driving it around in the hot weather it kept the oil bang on 80 deg no matter how hard it was pushed.... However now that it is cold, due to the size of the cooler and the fact that even when not up to temp a small amount of oil is flowing through the cooler this was enough to stop the oil warming up sufficiently.
Break out the card board and make a template
and have replicated in stainless steel
remove other cardboard template
insert new stainless item with foam pads to hold it away from the cooler and prevent rattles.
also figured I would check over the base idle and timing since fitting all the new breathing mods, the idle needed raising from around 900 rpm and the timing needed advancing a few degrees![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
runs sweeeeeet now
tracking and alignment booked for friday, since changing the rack bushes the wheel is a little off.
![IMG_0555.jpg](http://i881.photobucket.com/albums/ac16/SamThe/IMG_0555.jpg)
![IMG_0556.jpg](http://i881.photobucket.com/albums/ac16/SamThe/IMG_0556.jpg)
![IMG_0557.jpg](http://i881.photobucket.com/albums/ac16/SamThe/IMG_0557.jpg)
![IMG_0558.jpg](http://i881.photobucket.com/albums/ac16/SamThe/IMG_0558.jpg)
![IMG_0560.jpg](http://i881.photobucket.com/albums/ac16/SamThe/IMG_0560.jpg)
runs sweeeeeet now
