srbryan N15 Pulsar VZR DP1
Was it a second hand alternator you swapped out for and why ??I'd be thinkin that as the main possibility
was a new/reman alternator because the batt light was on and overcharging but after putting in the new alternator turned out to be a broken signal wire by the relays on the d/s.
Whilst waiting for a few bits and pieces decided to paint my valve cover as it was looking a little bit worse for wear and scratched and chipped.
Years of grime
With the cover removed I was happy to see it was very clean and gave a quick look around the cams and rockers and very little signs of wear.
So got a plastic bag and put it over the head to stop anything falling or making it's way in whilst i was painting.
Cover removed and ready for cleaning and painting.
Gave it a good scrubbing both inside and out before i put on nitro-mors
And masked up
'DSC_0861.JPG Be surprised, just take off the throttle body disconnect all the pipe work and whip off the 10mm bolt's around it.
Bought a set of wheels today, I got Rota Sub-Zero that came up at a very good price. 16x7 et 40.
I'm not too gone on the white tho so i'm open to suggestions for what colour i should change them to.
I've got the wheels the rotas are based on, in the original champagne colour, really like it.
The ones on mikes looked ridiculous, 18s have no place on an N15.
Came across a fella breaking a 00 Almera and ended getting 2 arch liners in near perfect condition and 2 door hinges for the passo side, all that for €15 bargain i think. All i need to get now are 2 hinges for the drivers side and ill be sorted:)
I'm sick to death of planning work on the car around the weather, so got a cover and moved the Silvia out the shed for a week or 2 and moved the Pulsar so hope to get loads done over the next couple weeks.
