Stu-E Autech Engine
^ this
80w-90 GL4
or if you want it Ive got some Redline MT90 oil you could have for £30 cost me over £70..... basically the best oil you can buy :)
Already have some at my dads I was curious to whether I needed to change it mate, those pulleys you sent a link to were bloody sold :(
A small update thanks to the guys on the previous page I aquired some RR lifters and set about bleeding them last week.
Cams out ...
And some shiny lobes mmm :lol:
Also found the crank/oilpump case to be cracked and welded :(
A new one is ready for me to pick up as is the new crank pulley (cant afford lightweights just yet)
Some driveshaft oil seals are also on route as are some new coolant hoses.
Hopefully she will be ready for fitting in the next week or so, can't wait :lol:
Autech ones mate, that's the main reason i didnt have your seals as i had already took it all out once :lol:
Me and my old man set about refitting the new ish oil pump and case took a few pics while the main sump was off
All fitted and sealed back up using high temp rtv sealant.'
Just need a new clutch now and some plugs and its all ready for fitting :)
yh be careful pal how much sealer your using mate its not a case of more is better on engines pal.
also got your text flywheel not a chance lol need it to much also got you a lift
To be fair it ain't as much as it looks we barely used a small tube of sealant and we only put on as much as we scraped off :) lol
Did you get my txt about postponing from this weekend Rich?Ii
Not much has been done over the last few weeks as I've been on holiday, jae etc but got a new clutch kit yesterday and got around to fitting it :)
Going to pick some bits off Dale soon, then its ready finally :)
Sent from my Ginger Villain
Moar parts :)
Old
New
The new seals seem to be of better quality than the ones I took off as well.
I ordered some new coolant hoses from cougar performance, a fella called Roy was extremely helpful and postage was next day so sweet for that.
Nothing left now barring that pipe off Dale and arranging a weekend to make a start on it :)
did you wipe down the pressure plate with some brake cleaner before fitting it on? they come with a transport oil to stop them rusting in storage
