This is what you need Plus a few other bits but this is prettmy much it.
1. Nissport Adapters for water cooling the turbo. They Plum into Top and bottom hose and use braided lines, Looks the business and is very reliable.
5. Gauges 9boost guage.. oil pressure guage..) anyone who says get a narrowband AFR guage to tune from need shooting.. you need a proper wideband lambda sensor and readout to tune properly with..
6. Dasktek Piggyback ECU or greddy e-manage (ultimate can remove your AFM with a MAP sensor
7. oil pressure switch and T-piece
8. Manual Boost controller
10. 200sx Injectors
14. Sard FPR
17. Autobahn666 intercooler kit
18 GtiR manifold and GTiR t28 turbo
The agreed limit of a fwd car is around 240bhp before it gets stupid. Easily achievable with a setup similar to mine.
If you develop a thirst for more power, develop a thirst for a different drive-train at the same time
youll also need a drill and tap fitting and pipe for the oil return..
i just broke your list down to the basic form of what you would need to get it in and running at 10psi you could change your clutch if you want to but its not gona stop the car working leaving it standard..
If you develop a thirst for more power, develop a thirst for a different drivetrain at the same time
I think that 230 horse would be perfect for the GTi, just look at what the VZR N1 is like.
As far as im aware, im the only one flying about in a turbo'd GTI atm..
....without changing internals..to get over the compression problem.. get a thicker headgasket and use a large front mounted intercooler.. with good air flow..
You're not very aware then, unless you mean a sr20de+t gti.As far as im aware, im the only one flying about in a turbo'd GTI atm..
I thought standard compression was 9.5:1?
