The bumper is touching the wheels.. Soon as you add wind load to it its byebye bumper
Fucking disgusting.
Good work on the trials but imo it doesn't work the liner lines are very sharp and kind of square and it just doesn't work with the N16 rounded looks
....phone....
edk;621380 said:I think you could easily blend a cutout on to this. Also use the tops of the stock bumper where it meets the wings. Plus in my opinion you need to match the skirts and traffic apron to suit.
What part needs treating? I've not done mine since new and there's no rust.
Yes 5kg up front you're going to feel it wallow a lot with the heavy front end. Id recommend minimum 7kg for us.
-phone-
Wow - that's some amount of crud on those coilies I gave mine a clean every time the wheels were off, but smearing some vaseline on the threads helps to stave off the salt in winter.
Thanks fellaNICE motor, lovely find - not even ran in yet lol
Wow cheers Ed dont even need to write up a reply now. Exactly what Eds replied above LiamWhere did you buy the kit? DB Power?
I see. The discs wont need turning down then, they wont be bigger enough and the pads will overhang.
Im talking about the brackets. They will hold the caliper spaced for a 312/313mm disc so the pads will overhang the edge of the discs.
