My enthusiasm continued. Although I may have gotten a little excited with the grinder.
Decided I would rub down and primer inside the front arches. First task was to try again to undo the 3 rotten/round nuts on each arch (ones that connect to the bumper). I gave up after 30mins and got the grinder.
Passenger side;
Definitely need new wings now.
All rubbed down.
Zinc 182'd.
Mmm 4pots.
Driver Side;
Found a little friend. Good job is wasnt a false widow, could have eaten me alive!! :O
Found a round hole so cut a rectangle.
Seagul shat some plate over it.
Seam sealer'd and Zinc 182'd.
Mazda fag.
So, tomorrow im actually going to start cutting the passenger side. Ill have to remove the carpets first though as a patch needed on the single skin part of the floor. Then Ill turn the car round and drop the rear subframe so I can strip, paint and poly bush it.
Passenger side;
All rubbed down.
Zinc 182'd.
Mmm 4pots.
Driver Side;
Mazda fag.
