where did you get it from sam?
and how did you fit it in?
ive got the exact same center console as you and ive got my cd player in the bottom section with a open space above, but cant see how ive got to fit it in :/
Looks smart Sam, will be doing this when the VE goes in. Could do with a 17" monitor on the dash though, as down by the radio was the last place i was looking, when mine went at mallory. lol
My passenger will always be tasked with keeping an eye on them,
I will take pictures of it all seperate for you stu when I wire them in, they fix to the same bracket the stereo gets screwed to, I have one of the little dash pockets back in there now which screws in just the same.....
i think the defi guage sets which come with an aditional warning lamp are best for serious track use.. you have the guage mounted where its conveinient but they can drive a seperate LED that flashes when you get to a pre designated temp/pressure.. just like a shift light.. a few LEDS on the top of the dash binical is alot better than checking guages all the time!
not sure how to set them if Im honest Ive just taped the wires I dont need back to the loom, front panel has been delivered too
when I swapped the manifold from the gti I left the lambda in, all my stuttering/stalling/hesitation issues appear to have stopped happy boy, and for the first time Ive actually had a resonated decat do something it has stopped the rasp that used to be present around 3k sounds much deeper now, I really need to get a decent mid section made up now :roll:
came with the gauges Il take a proper photo of it when I get a chance, its not a clip in one you can fix it to the metal cage, which Im very happy about
No its not on a lovely clean surface with acres of space, try it on a rusty piece of shit at the end of a sill or similar on a ramp, then it becomes more of a skill!
up inside the rusty wet inner arch of a transit van with the welder one side of the axle and your arm on the other just to get enough space.............. that was a great first ever welding experience :lol:
