Did you get to the bottom of the weird Swift spring lengths? I guessed that they did those lengths as springs being so stiff didn't need the travel?
These are aluminium fasteners Bro. My budget only stretches to using Ti bolts on stress areas.Looks good. More titanium bolts there?
Metric coilover springs are universal in that they will fit any coilover damper so long as the diameter is correct. Swift makes metric coilover springs of different diameters eg. 62mm, 65mm. The 65mm will fit a BC Racing coilover damper but as per above unfortunately the problem is not the spring length.Or they are universal springs
Springs have been upgraded to Swift racing springs from Japan. The only problem now is the Swift springs are too short. I specified 200mm height springs but got 152mm fronts and 178mm rears
You might want to reread and understand what I actually said above before passing the comment.So you're using springs shorter than the factory specify, but you think its a BC damper problem?
I don't think you know what you're talking about.
Yes. Swift springs are offered as an upgrade by BC Racing.and they knew about your spring choice and weight of the car?
I still see it as a spring problem not damper. I mean you said it yourself, you wanted 200mm but they sent you the wrong ones...
-phone-
Im sorry but i think your installer doesn't know what he's talking about.
If the springs were longer you would be able to set the preload with a longer piston travel. End of.
-phone-
