My JDM Y0 Pulsar Serie GTi
cheers peps :)
im gonna be keeping the mount thats is there, but im replacing the rubber bit,
that is the bit i need to know which is which? will my sr20 poly mount go in there?
the gti one is definately different, mine is the same as yours.
will be interesting to know whether or not it needs a 2 piece mount or one of the single piece ones
When I fitted my polymounts, the rear mount fitted fine, but the `gearbox` one was too small, so I had to use the 2 piece mount on the gearbox, yours looks to be the same as the GTi one, only turned 90*.
well i guess the only way to get is to take it out and measure it ? sam is yours out? i think it is isnt it, when you removed the lsd box? :)
is what out?
GTi Mount
Autech Mount
cheers sam,
na i thought you removed your box to refurb it? :)
i dont a have a std gti box box to measure :( my red gti one brok in the crash :(
what insert wil li need , rear gti or gearbox gti?
I did remove my lsd box, but I just reused the mount on the gti box....
I still reckon you will need the two piece mount
lots n lots of digging, I now think you will need one of the single piece mounts...
the same mount as ours has the same orientation ye see
would you be able to do a full list of everything you used to relocate your battery... :)
yeah sure sam :)
haha good job you didnt order them up ay :)
Basically the poly mount KIT you buy from gspec contains 2 rears, 1 front and 1 drivers, but this is different to the uk gti, but seems perfect for the imports yO! :lol:
yeah cheers mate wanna get the boost up too 1bar/14psi well double wht i was on before :lol:
is it ok if i have that mount back? please..... X
