My N15 VZR
Was Good fun to them and nice to now for myself and not just thinking it haha
Any one recommend an Air intake set up? Currently runnning a STD air box with Doluck Panel Filter? with a cold air feed
What about a longer pipe with a velocity stack up near the battery with a heat shield?
Nice work on testing each header for results.
So I see you swapped he headers over within 1 hour of each other and the runs. Quick work.
Also I take it the exit diameter on the headers must have been the same to bolt on to the exhaust system you have.
On another note
Dale delivers again...All day everyday.
Yah we Did around 4-5 Runs on each Mani, Then Jacked it up and whipped em out, had Help of course :)
Bolted on just fine to my 3 " decat
And Yap Dale Delivred haha, top notch
Was on route to get a VZR N1 but got beating to it earlier ,
So Went and fitted my New
JBL 6x9s And ITG Air Filter Out of Sheer depression haha
Thanks To Kurt for the Filter, ITs HUGE haha
Deffo Needs A Heat Shield But Im not to sure what its done power wise,
Made the Car ignorantly Loud Tho,
Going To Move the Battery And Build a box as its a bit cramped
Few Other Photos
I must get the Apexi Catbcak to Pull Slightly More towards the bumper, Dont like how it sits
I have bar one, but have one on it noq, must Move it the weekend anyway and use the angled bend and throw the battery in the boot
Yeah wezz Its a genuine one I got off a vzr i broke :)
Should be Going for a map with the cams soon,
Absoluty Gutted i didnt get that 20ve that Andy had :(
Awesome chief. Should be juicy when you get some larger lobes in there.
Yeh two litres for the torque win like, just bosh some DE rods and crank in there and a little fiddle with the pistons
Only Going For n1 Cams but sure every little Help
Yah I keep Telling Myself it wont cost much but then, new bearings, Pistons, Rods and what not With labour I cant afford it atm,
Ill do it over the next year hopefully, Hoping to Go To a Drag event November 11th,
Hoping to pull a 14.5 at least :)
Yeh thats the only downside like, helps if you can build it yourself of course.
Yeeeeh bwoi get that launch right and it should be doable
