I test fitted my new turbo yesterday.
I wasn't sure that I would have enough clearance due to the bigger compressor housing. And I was right to a point. I thought it would foul on the block, but this wasn't the case. It was fouling on the front engine mount bracket. I took the bracket off the car and trimmed roughly 5mm off it, sanded the bracket and repainted it with some black caliper paint I had laying about.
It looks as tho its just a brand new bracket now. you wouldn't be able to pick its been modified.
Here is a pic with the new turbo on it:
I pretty much lost all motivation to pull it off and put the stuffed t25 back on it, but I want to go about doing this properly. I'm still waiting on a few parts to arrive(new gaskets and compressor inlet/outlet flanges) before I go about installing it permanently.
The wastegate actuator also needs to be modified to suit the rotated compressor housing. I'll be speaking to my engineering bloke as to whether its best to do it on the car, or to just take the turbo to him prior to fitting it.
