Not much has happened lately with my N16(well in the case of further mods), but i've been dealing with a few annoying problems that have arisen.
Approximately 6-8months ago, the bearings in my alternator became rather noisy. At the time I didnt have the cash to throw a new one on it, so I opted for a used one from a car wreckers. Last month I ran into some issues, where the car was starting, idling fine and would rev fine in neutral or in gear whilst stationary. But when trying to take off, the car would rev, then virtually die(it would hold revs about 1100rpm while at WOT) so something wasn't right. I pulled my hair out for about 6 hrs, swapping various parts over to no avail. Did a bit of a search on B15U.com and my symptoms were pointing to the alternator. A simple test with a multimeter revealed it was overcharging.
Heres a pic with all 3 alternators:
While I was at it, I noticed a heap of black soot on the head, near the exhaust manifold. I figured I had a spare gasket laying around, so it would be pretty easy to swap it over. Rather simple fix, you'd think? I've since replaced the gasket, but now the car is struggling to hit boost. I have a funny feeling its leaking from between the compressor housing and CHRA as the comp housing seems to have rotated slightly. The cars now booked in to my mechanics on wednesday to have a book leak test performed by way of a smoke machine.(basically I wanted to confirm the problem before pulling the car apart to fix it).
After i'd booked the car in last week, I stupidly left the key in the car overnight, with the ignition turned on, which completely drained the battery. I tried using a battery pack and jumper leads to jump start the car, but to no avail. I've had the battery recharged and tested and the battery is ok.
Now I'm hoping that the boost leak issue is a simple fix. I'm hoping to be able to purchase some new 225/40-18 federal 595 rs-r's next week.
Some of the guys on the Pulsar Group of Australia facebook group have organised a drag night on the 6th march at the local drag strip, so i'm aiming to have the car at its best. I'm aiming to hit a 13sec pass, which should be doable.
