Another little update...
Bought some service bits, including new outer CV boots...
Loom on the left of the engine has be relocated, but keeping the water temperature sensors obviously...
Cleaner looking without the loom on the left...
Nice and clean...
So today ive gathered up the last service bits, removed the clutch arm and cable bracket from the gearbox, gave the 'box a final clean and degrease, painted the 'box, then had a quick look at the N16 wiring...
The wiring was almost as Phil has listed, the speedo sensor wiring doesn't run through with the ECU loom, instead it goes around the engine bay and in to the cabin on the driverside and there was a couple of different colour wires... bloody Nissan! I didn't take the dashboard off today but I'm tempted to now just to make sure the rest of the wires are actually going where I think they are!
But anyways my findings on the wiring side...
Phase 1 N15 GTi
Interior Loom (small connector)
[TABLE="class: grid, width: 400, align: left"]
[TR]
[TD]
Pin [/TD]
[TD]
Wire Colour [/TD]
[TD]
Description [/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Brown[/TD]
[TD]IGN Live from Interior Fuse Box[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]Red[/TD]
[TD]Rear Demist load sense[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]Brown/Yellow[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]White/Blue[/TD]
[TD]From NATS IMMOB and 7.5a Battery Live (interior fuse box)[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]Black/Red[/TD]
[TD]Starter +VE to fuse box and Dizzy[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]Red/White[/TD]
[TD]? (was meant to check this today but forgot)[/TD]
[/TR]
[/TABLE]
Interior Loom (large connector)
[TABLE="class: grid, width: 400"]
[TR]
[TD]
Pin[/TD]
[TD]
Wire Colour[/TD]
[TD]
Description[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Purple/White[/TD]
[TD]PSP Pressure Switch[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]Dark Green/Red[/TD]
[TD]Consult Port[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]
Blue/Red[/TD]
[TD]
Air Con Relay[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]Green/Pink Dot[/TD]
[TD]Unused connector near bonnet catch[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]
Yellow[/TD]
[TD]
Air Con Relay[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]EMPTY[/TD]
[TD]EMPTY[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]Light Green/Red[/TD]
[TD]Rad Fan Relay[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]Black/Pink[/TD]
[TD]? Relay (forgot to check this aswell)[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]NATS IMMOB[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]EMPTY[/TD]
[TD]EMPTY[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]Black/Yellow[/TD]
[TD]From 7.5a Starter Fuse (interior fuse box)[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]Green/Orange[/TD]
[TD]Neutral Switch (comes from engine bay and back feeds to the ECU through this connector)[/TD]
[/TR]
[TR]
[TD]
13[/TD]
[TD]
Pink[/TD]
[TD]
ABS[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]Green/Black[/TD]
[TD]Consult[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]Grey/Blue[/TD]
[TD]Consult[/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]Dark Green/White[/TD]
[TD]Consult[/TD]
[/TR]
[TR]
[TD]17[/TD]
[TD]Blower Load Sense[/TD]
[/TR]
[TR]
[TD]18[/TD]
[TD]Purple/Red[/TD]
[TD]Speedo feed from clocks to ECU[/TD]
[/TR]
[TR]
[TD]19[/TD]
[TD]Orange/Blue[/TD]
[TD]MIL[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]Blue/Orange[/TD]
[TD]RPM Feed[/TD]
[/TR]
[/TABLE]
3 connectors on left side of engine
[TR]
[TD]
Top/Middle/
Bottom Plug[/TD]
[TD]
Wire Colour[/TD]
[TD]
Description[/TD]
[/TR]
[TR]
[TD]
Middle[/TD]
[TD]
Yellow/Red[/TD]
[TD]
Alternator[/TD]
[/TR]
[TR]
[TD]Middle[/TD]
[TD]Green/White[/TD]
[TD]Reverse switch output[/TD]
[/TR]
[TR]
[TD]Middle[/TD]
[TD]Yellow[/TD]
[TD]Reverse switch +VE feed[/TD]
[/TR]
[TR]
[TD]
Bottom[/TD]
[TD]
Black[/TD]
[TD]
Earth (alternator)[/TD]
[/TR]
[TR]
[TD]Bottom[/TD]
[TD]Black/White[/TD]
[TD]Starter Solenoid Signal from ign barrel[/TD]
[/TR]
[TR]
[TD]Bottom[/TD]
[TD]Neutral Switch (feeds to interior loom connector as in the above table)[/TD]
[/TR]
[TR]
[TD]
Bottom[/TD]
[TD]
Red/Black[/TD]
[TD]
Alternator[/TD]
[/TR]
[TR]
[TD]Middle[/TD]
[TD]Red[/TD]
[TD]Speedo Sensor[/TD]
[/TR]
[TR]
[TD]Middle[/TD]
[TD]Red/Yellow[/TD]
[/TR]
[TR]
[TD]Middle[/TD]
[TD]Pink Blue[/TD]
[TD]Oil Pressure warning light[/TD]
[/TR]
[TR]
[TD]Middle[/TD]
[TD]Coolant Temp Gauge[/TD]
[/TR]
[TR]
[TD]
Top[/TD]
[TD]
White x2[/TD]
[TD]
Alternator Live to interior fuse box[/TD]
[/TR]
[TR]
[TD]
Middle[/TD]
[TD]
Blue/Red[/TD]
[TD]
Air Con Compressor[/TD]
[/TR]
[/TABLE]
UNDERLINED means they are not needed and can be removed from the Loom.
ITALICS means I didn't need them so they were either removed or left in place. I didn't look any further into the routes/feeds of these as I had no need.
The Alternator will run off the N16 loom. The plugs are the same and the pins are in the same order.
Now I have also removed the NATS wiring loom from the N15, I have it all written down and I see no reason what so ever for it not to work when wired in to my N16. It is actually a very simple setup, a battery live, an IGN live and earth, the transponder ring an LED and 2 central locking feeds. There are only 2 wires that go to the ECU. I will not be posting the actual wire colour codes/routes publicly. If you need this info then please PM me
The consult port is a simple install too, simply 5 wires to connect up to the ECU. Although if you trace the wiring from the plug itself, it takes you on a bit of a goose chase, with a splitter and a few pairs of wires going to the ABS system and the Airbag/SRS system!
Now for the N16. I haven't traced all of these yet so they still need to be confirmed, ill do that at the weekend.
White connector by ECU
[TR]
[TD]
Pin[/TD]
[TD]
Wire Colour[/TD]
[TD]
Description[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Light Green[/TD]
[TD]OBD related[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]IGN Switch Start +VE[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]White[/TD]
[TD]? (Couldn't trace without removing the dash)[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]Black[/TD]
[TD]OBD Plug Earth[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]Pink/Blue[/TD]
[TD]Oil Pressure Switch[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]RPM to Clocks[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]Blue/Red[/TD]
[TD]A/C related[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]Green/Red[/TD]
[TD]OBD Related[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]Purple/Red[/TD]
[TD]Speedo from Clocks to ECU[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]Malfunction Indicator Light (MIL)[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]Blue/Black[/TD]
[TD]Lights load sense[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]EMPTY[/TD]
[TD]EMPTY[/TD]
[/TR]
[TR]
[TD]13[/TD]
[TD]EMPTY[/TD]
[TD]EMPTY[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]Black/Pink[/TD]
[TD]??? (phils list suggests fuel pump relay)[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]Black[/TD]
[TD]NATS IMMOB[/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]NATS IMMOB[/TD]
[/TR]
[/TABLE]
Brown Connector by ECU
[TR]
[TD]
Pin[/TD]
[TD]
Wire Colour[/TD]
[TD]
Description[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Light Green/Black[/TD]
[TD]A/C Load Sense[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]EMPTY[/TD]
[TD]EMPTY[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]Red[/TD]
[TD]Overdrive Light (Auto only)[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]Brown[/TD]
[TD]? (couldn't trace without removing the dash)[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]EMPTY[/TD]
[TD]EMPTY[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]? (Phil suggests 02 Sensor +VE)[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]Yellow[/TD]
[TD]Fuse to PSP Switch[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]Water Temp Gauge[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]Black/Red[/TD]
[TD]IGN +VE (not entirely sure where it goes)[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]Grey/Red[/TD]
[TD]Rear Demist Load Sense[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]White[/TD]
[TD]? (Phil suggests ECU relay, failed to trace)[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]EMPTY[/TD]
[TD]EMPTY[/TD]
[/TR]
[TR]
[TD]13[/TD]
[TD]EMPTY[/TD]
[TD]EMPTY[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]forgot to write down[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]White/Blue[/TD]
[TD] +VE can't remember is IGN was on or not :S[/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]Reverse switch to lights[/TD]
[/TR]
[/TABLE]
Connector on Suspension Turret
[TR]
[TD]
Pin[/TD]
[TD]
Wire Colour[/TD]
[TD]
Description[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Black[/TD]
[TD]Earth[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]Didn't trace[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]Green[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]Cooling fan relay to ECU.[/TD]
[/TR]
[TR]
[TD]5[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]Red[/TD]
[TD]A/C Related[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]Red/Yellow[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]Red/Blue[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]Black/White (thick wire)[/TD]
[TD]Starter Solenoid Signal from Ign barrel[/TD]
[/TR]
[/TABLE]
As you can see I've not filled in the Description for the N16, purely due to me wanting to trace the wiring.
Thats all for today folks.
