N16 SR20DE
Before
18 in its sights
During
After
Nah not got it started, will be going out there tomorrow after work to hopefully track down that NATS Dongle and sort out the brakes :)
EDIT - Yeah it stings a little, good job it was the flappy disc and not a cutting one tho! Roger has moved the the Wirral :(
Whoo you got the p2 lights sorted :thumb:
Good progress on the engine/cross member dude :)
  • Like
Reactions: IT
Those pics are from when i first fitted them Ed, they aren't sat right, if you look closely at the 1st and 2nd pics you can see the difference in the gaps underneath/on top!
Err, couple of weeks before Twizzy came along :)
Thats the plan :)
Well the todo list as it stands;
Locate and replace NATS Dongle
Re-assemble dashboard
Make up new OSF brake pipe
Fit front brake flexis
Bleed brakes
Bleed clutch
Fit catback
Put wheels on
Test drive
Then full service :)
Ammar, FAOC is still going ahead, ive been putting my time/cash into this recently so its been sat on the side lines. Once ive got this going and out of the unit, ill strip the rest of the parts off the Sport+, cut up Grandad, get the leftovers scrapped and crack on :)
(with rolled arches) perfect fit is front 7J ET+30, rear 7J ET+22 (my rears are 8J ET+35 but it's the equivalent) :).
So those are spot on for the rears but you'll need to find some +30s.
Hrm. 5mm... I'll stick my 5mm spacers on the front of mine and see how they sit ;)
  • Like
Reactions: IT
