Lol, excellent vds poc.
I'm about to start a similar build DE block, N1 head, N1 or Kelford 184C cams. Any advice or things I need to be looking out for?
Great stuff well at least you have a bit of a guideline!!
Where you getting N1 head???
Id go with N1 cams or wait for High N1 low 20ve cams, there in testing at the mo.
What pistons are you going using ?
Do you plan on opening up bottom end?
The highest rpm mine seen was 8300, eventually found out it was damaged pistons from bad fuelling. Must have occured early on in build and weakened pistons or else in 5th gear at 6krpm after i sold it!
Any more pics of that header?
New design for the header.
+12 hp on a modded 20ve.
Available now for 580 euros + delivery from Greece.
