Getting to the stage of re-assembly, I wanted to finish up the wiring by soldering the wires i cut.
Then went looking for my soldering wire and couldn't find it anywhere, spent about half hour looking for it and nothing, I felt so gutted cause it was a fairly new roll aswel.
So took off the old oil filter which was an absolute ball ache to get off, it was very hard to get off even with a filter band, was like it was overtightened when it was put on and hadn;t been off in ages.
Installed new filter and yes i know it's not the nissan filter but it was one i had spare around the place and i plan on changing the oil again after 2000km.
Filled the engine with oil then
And also finalised where the realy box was going but then came across a problem of how would i get the cover off to change a relay if i needed to, so i cut one side of it off so i it can still bed slid over the relays and be removed easily if need be.
And also put back on the passo wing and left it at that, hoping to get loads done tomorrow eve after i get solder.
