ill just have to wait till next month till i get paid again to get this,
just droped in craigs flywheel at the garage and had a lokk in at my engine,
had a look at the old pistons and the first 3 are ok just got a little bit hot but still ok,
but piston 1 is FUCKED!!!! as in like 1cm of metal is missing OMG!
it got extremely hot, pic to come soon,
and the block has a 3mm hole/dip/wear mark in the side,
other than the lump of missing piston the piston edge all the way around is really badly worn is it has got so hot and expanded scoring the whole piston and bore really bad![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
ill be driving up to craig to pick up a block in the next few days![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
the head is fine just needing 1 new valve on the exhaust side, of the number 1 cylinder,
getting the turbo sent off thursday, for a check over and service/balancing etc![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
ill be putting the crank, rods into the new block as they are better, and itll be bored out to 87mm from 86mm,![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
not long now![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
maybe getting some new injectors to, just to be on the safe side, anyone know where i can get them ultrasonically cleaned and tested![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
not long now
